estousandy
Newbie level 3
This was my final sem college project. We designed a simple zigbee based walky-talky and found it stable till 100mtrs.
Anything above this range require an xbee module with external antenna connector (rpsma) or experimenting with a
whip antenna. Clock was set at 48MHz using internal multipliers as output was less clear with lower clocking.
Mikrobasic code
_______
program picpgm
Mikrobasic code
_______
program picpgm
Code Basic4GL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 dim k, i, ch,X,b0,b1,b2 as byte ADV AS WORD sub procedure Init_Main ADCON1 = ADCON1 or 0x0F TRISA = 0xFF TRISB = 0 TRISC = %10000000 TRISD = 0 end sub main: Init_Main() Usart_Init(115200) Lcd_Init(PORTB) Lcd_Cmd(Lcd_CURSOR_OFF) Lcd_Out(1, 2, "WALKY-TALKY") Lcd_Out(2, 1, "ZigBee 1 2.4GHz") while TRUE if Button(PORTC, 0, 1, 1) then if Usart_Data_Ready = 1 then b2 = Usart_Read end if PORTD = b2 else adv = Adc_Read(1) x = word(adv >> 2) Usart_Write(x) end if wend end.
