Vivaldi antenna HFSS Design Tutorial?
enrobria
Newbie level 3
Can i have HFSS step by step Design tutorial for Vivaldi antenna? Like the one present for patch antennas etc.
its hard to find Viavaldi antenna tutorial , also usually in paper didn't give full data about this antenna dimension
I am having a really hard time in designing the exponential curve of vivaldi antenna in HFSS and my HFSS skills are also very basic. So no idea what to do :(
in edaboard search vivaldi i seen a text about curve of vivaldi i hope it helpful for you
Does the HFSS antenna design kit have the facility to design such an antenna? I don't know, but it is possible it does.
dave
antenna design kit can design viavaldi antenna with low frequency and limited bandwidth
You can write those equations of exponential curve in matlab to evaluate those points . later use polyline in hfss and enter the end point values in polyline to get your curve
Here is a Matlab to HFSS program. If you get it to work let us know.
did u design it finally?? i am having same problem with the taper curve? how do u design the curve in HFSS?
if u make the curve using "equation based curve" you cant not change it co-ordinates and even if u try to thicken sheet its will directly become "non assigned model". how do u cut the surface from patch? please help needed badly!
Take a look at the file included in the thread: [ https://www.edaboard.com/threads/283776/ ] . It is parameterized. So you should be able to change a number of factors in the design.
It was generated using the HFSS Antenna Design Kit.
