evilengineer1
Newbie level 6
I want to visualize B1 field in Matlab. I am using REMCOM software and I get the data stored in bin file from the software and now I want to visualize it in Matlab. But, whenever I try to run the code I get this error:
Error using reshape
To RESHAPE the number of elements must not change.
Error in ReadData (line 112)
data_X = reshape(dataEx, xdim, ydim, zdim);
Error in OpenFiles (line 28)
[dataBx, dataBy, dataBz]= ReadData(infoFile, gemFile, dataFileBxr, dataFileBxi, dataFileByr, dataFileByi,dataFileBzr, dataFileBzi);
The code is given below which is essentially divided into two files. The first one is Readdata.m and the code is:
function [data_X, data_Y, data_Z] = ReadData(infoFile, gemFile, dataFileBxr, dataFileBxi, dataFileByr, dataFileByi, dataFileBzr, dataFileBzi)
and the second file is openfile.m and the code is:
I am really stuck here. Can anyone pleas guide me. Any kind of help is appreciated. I have attached the bin file along with the matlab code with this question.
Error using reshape
% clear all;
% path = 'D:\work\matlab_work\B1-field\Run0001\MultiPoint_Planar_Sensor_0_';
% %path = 'D:\work\matlab_work\B1-field\25\MultiPoint_XY_0_'
% infoFile = strcat(path,'info.bin');
% geomFile = strcat(path,'geom.bin');
% dataFileExr = strcat(path,'steady_Bxr_total_freq0.bin');
% dataFileExi = strcat(path,'steady_Bxi_total_freq0.bin');
% dataFileEyr = strcat(path,'steady_Byr_total_freq0.bin');
% dataFileEyi = strcat(path,'steady_Byi_total_freq0.bin');
% dataFileEzr = strcat(path,'steady_Bzr_total_freq0.bin');
% dataFileEzi = strcat(path,'steady_Bzi_total_freq0.bin');
%-------------------------- begin '..._info.bin'
fid = fopen(infoFile);
Rmpt = fread(fid, 4, 'char*1');
version = fread( fid, 1, '*uint8', 0, 'a' );
bitmask = fread( fid, 1, '*uint32', 0, 'a' );
hasTimeDomainScatteredE = bitget( bitmask, 32 ); % 0
hasTimeDomainTotalE = bitget( bitmask, 31 ); % 0
hasTimeDomainScatteredH = bitget( bitmask, 30 ); % 0
hasTimeDomainTotalH = bitget( bitmask, 29 ); % 0
hasTimeDomainScatteredB = bitget( bitmask, 28 ); % 0
hasTimeDomainTotalB = bitget( bitmask, 27 ); % 0
hasTimeDomainJ = bitget( bitmask, 26 ); % 0
hasDiscreteFrequencyTotalE = bitget( bitmask, 25 ); % 1 if steady state E is requested
hasDiscreteFrequencyTotalH = bitget( bitmask, 24 ); % 0
hasDiscreteFrequencyJ = bitget( bitmask, 23 ); % 0
hasDiscreteFrequencyTotalB = bitget( bitmask, 22 ); % 0
geoSize = fread( fid, 1, '*uint32', 0, 'a' );
fclose(fid);
%-------------------------- end '..._info.bin'
%-------------------------- begin '..._geom.bin'
fid = fopen( gemFile );
xPos = zeros(1,geoSize);
yPos = zeros(1,geoSize);
zPos = zeros(1,geoSize);
for kk = 1:geoSize;
xPos(kk) = fread( fid, 1, '*uint32' );
yPos(kk) = fread( fid, 1, '*uint32' );
zPos(kk) = fread( fid, 1, '*uint32' );
end
fclose(fid);
max_xPos = max(xPos);
max_yPos = max(yPos);
max_zPos = max(zPos);
min_xPos = min(xPos);
min_yPos = min(yPos);
min_zPos = min(zPos);
xdim = max_xPos - min_xPos +1;
ydim = max_yPos - min_yPos +1;
zdim = max_zPos - min_zPos +1;
%-------------------------- end '..._geom.bin'
%-------------------------- get data values
fid = fopen( dataFileBxr );
dataExr = fread( fid, geoSize, 'single' );
fclose(fid);
fid = fopen( dataFileBxi );
dataExi = fread( fid, geoSize, 'single' );
fclose(fid);
fid = fopen( dataFileByr );
dataEyr = fread( fid, geoSize, 'single' );
fclose(fid);
fid = fopen( dataFileByi );
dataEyi = fread( fid, geoSize, 'single' );
fclose(fid);
fid = fopen( dataFileBzr );
dataEzr = fread( fid, geoSize, 'single' );
fclose(fid);
fid = fopen( dataFileBzi );
dataEzi = fread( fid, geoSize, 'single' );
fclose(fid);
dataEx = complex(dataExr, dataExi);
dataEy = complex(dataEyr, dataEyi);
dataEz = complex(dataEzr, dataEzi);
data_Y = reshape(dataEy, xdim, ydim, zdim);
data_Z = reshape(dataEz, xdim, ydim, zdim);
%data_X = reshape(dataEx, zdim, ydim, xdim);
%data_Y = reshape(dataEy, zdim, ydim, xdim);
%data_Z = reshape(dataEz, zdim, ydim, xdim);
clc;
close all;
clear all;
% Select the files
[files, path] = uigetfile('*info.*');
infoFile = strcat(path,files);
cd(path);
[files, path] = uigetfile('*geom.*');
gemFile = strcat(path,files);
[files, path] = uigetfile('*_B*.*', 'MultiSelect', 'on');
dataFileBxi = strcat(path,files{:,1});
dataFileBxr = strcat(path,files{:,2});
dataFileByi = strcat(path,files{:,3});
dataFileByr = strcat(path,files{:,4});
dataFileBzi = strcat(path,files{:,5});
dataFileBzr = strcat(path,files{:,6});
cd('C:\Users\UOUWIn\Desktop\Matlab code');
% Read Data
x = abs(dataBx);
y = abs(dataBy);
z = abs(dataBz);
img = sqrt(x.*x + y.*y+z.*z);
img_size = size(img);
clims = [min(min(img)) max(max(img))*1.5E-1];
%% Display Results
h = figure('Name',path);
subplot(3,2,[1 3]);
h_img = imagesc(img, clims);
axis square; colormap jet;
%% ROI : Avg, std %
img_center = img_size /2;
e_position = [img_center 0 0] + [ -40 -40 40 40];
%e = imellipse(gca,[40 40 114 114]);
%e = imellipse(gca,[40 40 40 40]);
e = imellipse(gca, e_position);
%e = imellipse(gca, [20 20 40 40]);
BW = createMask(e, h_img);
Num = sum(sum(BW));
Avg = sum(sum(img.*BW))./Num;
tmp = ((img.*BW)-(Avg.*BW)).*((img.*BW)-(Avg.*BW));
std = sqrt(sum(sum(tmp))/(Num-1));
title(sprintf('ROI = %d\n Avg= %5.4f[uT], std= %5.4f[uT]', Num, ...
Avg*1E+6, std*1E+6 ));
subplot(3,2,[2 4]); contour(imrotate(img',90), 100); axis square
% ROI : Max, Min
max_img = max(max(img.*BW));
tmp =img+(1-BW);
min_img = min(min(tmp));
title(sprintf('ROI = %d\n Max = %5.4f[uT], Min= %5.4f[uT]', Num, ...
max_img*1E+6, min_img*1E+6 ));
subplot(3,2, [5 6]);
plot(img(ceil(img_size(1,1)/2),:), '-r');
hold on; grid on;
plot(img(:,ceil(img_size(1,1)/2)), '-b');
legend('x-dir', 'y-dir','Location','NorthEastOutside');
info_A = sprintf('%s\n',path);
info_B = sprintf('Avg[uT]= \t%f\n',Avg*1E+6);
info_C = sprintf('Std[uT]= \t%f\n',std*1E+6);
info_D = sprintf('Max[uT]= \t%f\n',max_img*1E+6);
info_E = sprintf('Min[uT]= \t%f\n',min_img*1E+6);
info_F = sprintf('Std/Avg= \t%f\n',std/Avg);
disp(info_A);
disp(info_B);
disp(info_C);
disp(info_D);
disp(info_E);
disp(info_F);
% % open the file with write info of Exp.
% fid = fopen('~/Expinfo.txt', 'a+');
% fprintf(fid,'\t%f \t%f \t%f \t%f \t%f\n', ...
% Avg*1E+6, std*1E+6, ...
% max_img*1E+6, min_img*1E+6, std/Avg);
% fclose(fid);
cd(path);
saveas(h,'Result.jpg');
cd('.\');
