Re: VIP HELP NEEDED...UWB Pulse generating circuit schemati
As I understand the critical point for TX UWB signal is the spectral mask. So simple pulses are not enough.
The basic pulse is in most cases a +1 for some 100ps and a following -1 for the same period. It is generate by a technology/temperature/voltage stable delay generator and logic circuits. Then the pulse is filtered by an bandpass filter which is special surpression in the GPS frequency range.
Sorry for link .
This is search for McEwan LLNL MIR patents the Stadero's radar is based on . You can go and search for "McEwan" in author field on freepatents site to get all his patents on issue . Patents mostly concern to MIR design modifications .
