vim/gvim commands in a shell script
vikramc98406
Full Member level 1
I want to execute vim commands from shell script
Below are two examples i can work in exec mode of gvim/vim and can edit a file
:%s/text1/text2/g
:r <filename>
Is there a way to execute the above commands without opening the file either on unix command line or embeded in sh script.
I am also trying to replace a path in file and expand full contents of that.
I am trying to embed in a shell script, can anyone help me
Thanks
vikram
If your just planning on using vim/gvim to perform text substitution why not use sed instead? You can shell script that without a problem.
Hi Ads-ee,
Instead of suggesting to use sed, can you help me how to use sed to "substitute filepath with its contents" by search and replace method.
I am also curious to know how to use vim exec commands without opening VIM editor, can anyone give me some info.
Thanks
Vikram
Hi Ads-ee,
Can you help me in using sed for the below command in VIM, as mentioned in my original post
:r <filename>
Thanks for the link, i will explore more.
Thanks
Vikram
Had to play around with the :r <filename> to see what it does. sed won't insert a file into another file as far as I know.
I think you should seriously just use a scripting language like perl/python/tcl to do this task. What you seem to be after is rather more complex than a simple text substitution. You seem to want to automate file editing?
Hi Ads-see,
I am looking at a simple solution, I have used vim editing with out opening vim editor.
so not not planning to use complex solution of using other tools.
Thanks for your suggestion, I will work on exploring more.
looking forward for some help from the edaboard community.
Thanks
Chait
