Viewing windows partition in linux: fstab file and NTFS
ashi
Member level 4
Egypt
Need help
I need to view the windows partions in linux , i used to do this by adding a line in fstab file but i was using FAT as file system but now i am using ntfs and when i use the same line (with replacing VFAT with NTFS) it doesn't work so can any one help me.
thanks in advance
Re: Need help
hi,
check this article;
TeE ThE EdE
Re: Need help
Check this site i think it is usefull
Re: Need help
You will need to download ntfs driver build for the kernel version you are currently running. You can find rpms on **broken link removed**. But, if you upgrade the kernel. you must also install the new ntfs driver which goes with that kernel version.
Re: Need help
use the mount command...but first u shud knw wat of ur partitions r ur windows partitions by using system tools-->hardware browser-->hddrives
den use mount command with -t option like
mount -t vfat /dev/hda5 /mnt/ (my hda5 is fat32 shown n windows as F:\)
/mnt/ is the folder where u will find ur windows drive contents...
