VHDL Programming, define a specific variable
karan1207
Newbie level 5
please can you suggest how in VHDL I can define a variable which is visible in multiple processes of different components,, for example, I need a common CLK
Re: VHDL Programming
For every component, you will define a clock input.
When you connect blocks, you will connect the same clock signal for every block.
Amr Ali
I have defined aclock input for every component, but how do i connect the clk. could u elaborate please. do i need to define the variable clk in the main program as global. how to do it?
Using the component keyword and pin assignment :)
Amr Ali
