avishai11910
Newbie level 2
Hello everyone I am a beginner electronic engineer, and i need to write a vhdl model for confifig with device ADV7511 in vhdl, i use with a code:
i use with table 23 and with RGB 10 bit style 1 in adv7511 datasheet , can anyone help me with what values i need to send to the register in adv7511 ?
this what i undestand from the datasheet:
the 2 bit in the left tell the adress, and the 2 bit in the right tell the data in Hexadecimal.
i on that two weeks and I can not understand. please help me.
thank you.
[Moderator action: email address deleted]
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 x"4110", x"9803", -- must be like this x"9AE0", -- must be like this x"9C30", -- must be like this x"9D61", -- must be like this x"A2A4", -- must be like this x"A3A4", -- must be like this x"E0D0", -- must be like this x"5512", -- need to be else for rgb or ycbcr x"F900", -- must be like this x"1505", -- RGB 444 x"4838", -- RGB 00 ?? -- x"4838",know is lsb to msb, else x"4818" msb to lsb, x"161A", -- RGB 444 10 bit style 1, 1st half on rising edge - YCrCb clipping ?? x"1710", -- output aspect ratio 16:9, external DE x"D03C", -- auto sync data - must be set for DDR modes. x"AF04", -- DVI mode x"4c05", -- Deep colour off (HDMI only?) - not needed x"4000",
thank you.
