Verifying bit_vector help needed
teteu86
Hi. I have these ports:
up: buffer bit_vector(1 to 11);
floor: buffer integer range 1 to 11;
How can I verify if there is as least one element after up(floor) that is 1?
For example:
up<="00100000001"
If floor is 2, up(floor) = 0.
If floor is 3, up(floor) = 1.
If I'm on 5th, how can I write a code to verify if there is "1" as element since up(floor+1) until up(11)?
process(up,floor)
begin
variable check: std_logic;
check:='0';
for i in 1 to 11 loop
  if i>floor and up(i) = '1' then
    check:='1';
  end if;
end loop;
result<=check;
end process;
Re: Verifying bit_vector
Thanks FvM.
I'm trying to write a code for a controller of elevator.
Until tonight, I'll post the results here.
