Endymion
Junior Member level 3
I have a program in VHDL that has a 16-bit shift register, a bit counter and a simple FSM. The bit counter counts down from 15. When the carry out is 1, we know we've reached 0 i.e. we've shifted in 16 bits.
At this stage, I'd like to verify that the shifted in address is the same as an internal constant. My question is, do I pass this shifted in data to the FSM for verification? As of right now, the FSM only has two states:
IDLE -> Address.
If I shift in the address, I can add in a 'address verification' stage and then shift in the data.
IDLE -> ADDRESS -> VERIFY ADDRESS -> SHIFT IN DATA
If the address isn't OK, the FSM returns to IDLE. Essentially, I'm trying to design a simple protocol over SPI that allows a uC to shift in (or shift out) data to various devices based on their internal address. I only want the data/commands to go the device whose being addressed.
Note: I know I can use Chip Select, that's what its meant for. However, I'd prefer using addresses. This is because the devices can be on different PCBs and I can't send a large number of CS lines over. Therefore, using addresses is something I'd prefer.
IDLE -> Address.
