PlayaSlaya69
Junior Member level 1
Hi all, i need some help is choosing the best pressure sensor for a project i'm doing. The sensor needs to monitor the pressure inside a sealed enclosure which will be vacuum sealed with the expected pressures to be in the range 50mbar to 150mbar. As far as i understand i need an absolute pressure sensor for this purpose. However the only pressure sensors of this type available in my country are expensive and the more cost effective variants have a measuring range of 0 - 100 kpa (0 - 1000 mbar), with a sensitivity of about 0.4mV/kpa. Over the 5V range of the microcontroller i intend to interface the sensors with, these sensors do not offer a high enough sensitivity to read values in the 0 - 150mbar range.
I have however found a similar product, with a range of 0 - 50kpa, and a sensitivity of 90mv/kpa, which i feel will be more suitable for the project, but it is stipulated as a guage pressure sensor. Although, as per my interpretation of the respective datasheet, the sensor is internally referenced to a vacuum pressure. Does this mean that this sensor would be suitable for my appliaction? I have attached the datasheet in this post.
Any help would be greatly appreciated as my knowledge of pressure and their measururement is quite limited. Thanks
