cat_carl
Newbie level 1
hspice license
gurus, here is my problem: when sim with va models in hspice 2007 (under windows), it cannot generate/find cml file. At the bottom is its related message in *.lis. I removed some unrelated lines. Left these lines to state the problem and prove license
Here I got 2 problems:
1) the CML path is directed to the Home path (the 'C:\PSD_DATA\hsp-model-cache\1.46\..... my $home is set at c:\psd_data by cadence)
- I have tried to set HSP_HDL_PATH. it doesnt help
2) the CML file wasnot generated
- I tried in command line. by hsp-vacomp.exe testfile.va -o testfile.cml, no cml file generated.
Anybody has experience on it?
thanks in advance
hsp-vacomp:
hsp-vacomp: Invoking the Verilog-A compiler for "E:work\current\testfile.va"
hsp-vacomp: lic: License/Maintenance for hspiceva will expire on 01-jul-2012/2007.09
hsp-vacomp: lic: Release hspiceva token(s)
** error **
During Verilog-A Device processing:
CML file does not exist
'C:\PSD_DATA\hsp-model-cache\1.46\E\\work\current\testfile.cml'
***** job aborted
lic: Release hspice token(s)
thanks in advance
hsp-vacomp:
** error **
***** job aborted
