UWB is Ultra Wide-Band Antenna. Single UWB- antenna can be used for multiple applications because its can support wider bandwidth.
For example if the antenna in the range of 50 MHz to 5 GHz
Then it can be used for FM Transmitter/Receiver (88MHz to 108 MHz).
It can be used for WLAN Applications.
It can be used for Bluetooth Applications Etc...
