beachlife
Newbie level 1
I am trying to upconvert a baseband signal, 500Mbps, to 10GHz. When I mix the signal with a carrier of 1GHz, I see a what looks to be the correct signal centred at 1GHz. But when I try to mix with 10GHz, I seem to get a signal much wider than the original. Can anyone please recommend what I am doing wrong?
Code PHP - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 %---------------------------------------------- clear variables close all clc %------------------------------------------------- %Raised Cosine Filter L=41; %Filter Length R=500E6; %Data Rate = 1Mbps Fs=8*R; %Oversampling by 8 T=1/R; Ts=1/Fs; alpha =0.2; % Design Factor for Raised Cosing Filter %Generate data of random 1s and 0s data=2*(rand(1,1000)>=0.5)-1; %Polar encoding : 1= +1V, 0=-1V output=upsample(data,Fs/R); %---------------------------------------------------------- %Raised Cosing Filter Design %---------------------------------------------------------- if mod(L,2)==0 M=L/2 ; % for even value of L else M=(L-1)/2; % for odd value of L end g=zeros(1,L); %Place holder for RC filter's transfer function for n=-M:M num=sin(pi*n*Ts/T)*cos(alpha*pi*n*Ts/T); den=(pi*n*Ts/T)*(1-(2*alpha*n*Ts/T)^2); g(n+M+1)=num/den; if (1-(2*alpha*n*Ts/T)^2)==0 g(n+M+1)=pi/4*sin(pi*n*Ts/T)/(pi*n*Ts/T); end if n==0 g(n+M+1)=cos(alpha*pi*n*Ts/T)/(1-(2*alpha*n*Ts/T)^2); end end %------------------------------------------------------------------------------------- y=conv(g,output); %Convolving the data signal with the Raised Cosine Filter Fn=Fs/2; NFFY=2.^(ceil(log(length(y))/log(2))); FFTY=fft(y,NFFY);%pad with zeros NumUniquePts=ceil((NFFY+1)/2); FFTY=FFTY(1:NumUniquePts); MY=abs(FFTY); MY=MY*2; MY(1)=MY(1)/2; MY(length(MY))=MY(length(MY))/2; MY=MY/length(y); f1=(0:NumUniquePts-1)*2*Fn/NFFY; %Plot Frequency spectrum figure; plot(f1,20*log10(abs(MY).^2));xlabel('FREQUENCY(Hz)');ylabel('DB'); grid title('Baseband frequency domain plots') % RF FFT ----------------------------------------------------------------------------- fc = 10e9; Fs = 4*fc;%fc; % Sampling frequency % Note that it is important that Fs is at least twice the carrier frequency T = 1/Fs; % Sampling period L = length(y); % Length of signal t = (0:L-1)*T; % Time vector y = y.*sin(2*pi*fc*t); Fn=Fs/2; NFFY=2.^(ceil(log(length(y))/log(2))); FFTY=fft(y,NFFY);%pad with zeros NumUniquePts=ceil((NFFY+1)/2); FFTY=FFTY(1:NumUniquePts); MY=abs(FFTY); MY=MY*2; MY(1)=MY(1)/2; MY(length(MY))=MY(length(MY))/2; MY=MY/length(y); f1=(0:NumUniquePts-1)*2*Fn/NFFY; %Plot Frequency spectrum figure; plot(f1,20*log10(abs(MY).^2));xlabel('FREQUENCY(Hz)');ylabel('DB'); grid title('Frequency domain plots')
