HyperText
Junior Member level 2
Hi, I'm programming a N-bit non-restoring divider, but I faced a little problem.
I have an Operative Part (combinatorial) and a Control Part (Finite State Machine).
The Control Part has a 2 processes FSM, 1 for updating the next state and 1 for the "state sequence".
And this is the second process:
As you can see, I need to change the value of the sub ONLY in 2 cases (subtract and test), while I don't have to change in the other cases.
The problem is that when I try to synthesize this code it turns out that sub_tmp is a LATCH, but I don't want a latch.
I need to do something like this:
state 1 => set sub to '1' or '0' (depending on another input)
state 2 => do other operations (but sub must remain the value set before) and return to state 1
etc...
To clarify more: in certain states of my FSM (not all of them) I set the value of a variable (let's call it sub_tmp). In other states I don't change its value. Then let's say I have an output PIN called "sub_out". Now, independently of the variable value, I want to output its value to this pin (sub_out <= sub_tmp; or similar).
What am I missing?
Thanks
update: process(clk_in, next_state)
begin
if rising_edge(clk_in) then
current_state <= next_state;
end if;
end process;
control: process(current_state, start, S_in, counted)
variable sub_tmp : STD_LOGIC := '0';
begin
sub <= sub_tmp; -- sub is an output signal of my entity that goes in the Operative Part
case current_state is
when idle =>
if start='1' then
next_state <= init;
else
next_state <= idle;
end if;
when init =>
next_state <= subtract;
when subtract =>
en_A <= '1';
sub_tmp := '1';
next_state <= test;
when test => -- shift
en_Q <= '1';
if S_in='0' then
sub_tmp := '1';
else
sub_tmp := '0';
end if;
if counted=N/2-1 then
next_state <= finished;
else
next_state <= operation;
end if;
when operation =>
en_A <= '1';
next_state <= test;
when finished =>
stop <= '1';
next_state <= idle;
end case;
end process;
etc...
What am I missing?
Thanks
