fmaximovic
Junior Member level 2
In my very simple schematic A there's something I'm not able to fix; its behavioral simulation had no problems but the timing one is a disaster (cf B, zoomed in C).
The first block performs the sum INTER_1 of two inputs A1 and A2; then INTER_1 is fed to a second block that sums (subtracts it) to a constant.
The code is after the jump.
Code of the first block (sums two 8-bit inputs into a 9-bit output):
Code of the second block:
UCF file:
And the testbench code is:
Ah, and of course the Timing Report said that there were no violations.
Thank you all guys!
process (CLK)
begin
if (CLK'event and CLK='1') then
S1 <= conv_std_logic_vector(conv_integer(A1) + conv_integer(A2),9);
end if;
end process;
architecture BEHAVIORAL of FUN_21 is
constant FO1 : std_logic_vector(7 downto 0):= "00001010";
begin
process (CLK)
variable RES_TMP : std_logic_vector(7 downto 0);
begin
if (B1(7) ='0') then --V1
RES_TMP := conv_std_logic_vector(conv_integer(FO1) - conv_integer(b1),8); --V1
else
RES_TMP := conv_std_logic_vector(conv_integer(FO1) + conv_integer(b1),8); --V1
end if;
T1 <= RES_TMP(7 downto 0);
end if;
end process;
end BEHAVIORAL;
UCF file:
NET "CLKX" TNM_NET = "TMN_CLKX";
TIMESPEC "TS_CLKX" = PERIOD "TMN_CLKX" 4 NS HIGH 50%;
CLKX <=not CLKX after 2 ns;
process(CLKX)
constant MXP1 : std_logic_vector (7 downto 0) := "01111111"; -- maximum positive value
constant MXN1 : std_logic_vector (7 downto 0) := "10000001"; -- minimum negative value
constant UN1 : std_logic_vector (7 downto 0) := "00000001"; -- unitary term for sums
begin
if (CLKX'event and CLKX='1') then
if IN_2 = MXP1 then -- if IN_2 reached its positive maximum, reset it
IN_1 <= IN_1+UN1; -- and increase by 1 IN_1
IN_2 <= MXN1;
else
IN_2<=IN_2+UN1; -- else increase IN_2 by 1
end if;
end if;
end process;
Thank you all guys!
