raf_prze
Newbie level 5
Hello, I want to insert some uni-planar EBG structure between two patch antennas to supress the surface wave, and thus reduce coupling effect.
My problem is, that I'm not abble to see the surface wave excitation effect. Even if i delete the substrate between antennas, S21 and S11 are not being changed.
Is there a way to enhance the surface wave effect? Or am I just probably doing something wrong with the simulation? What should be the right simulation settings?
I'm using CST MWS for simulation. I tried multiple frequencies between 2 GHz and 5 Ghz.
