UART Problem on CPLD c-m240 board
reservevoltage
Hi there,
Currently ı have worked on cpld demo board which name is cpld c-m240 (clone board). The board has epm240t100c5n cpld.
In this board, ı have tried to communicate with PC by implementing UART.
However, my code is not working properly on the board.
I'm waiting your a brilliant advice.
test code
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity test is
port(
start :	 in std_logic;
clk: 	in std_logic;
rslt:	out std_logic);
end test;
architecture davranis of test is
COMPONENT uart_tx
PORT(
clk: in std_logic;
reset: in std_logic;
inpt : in std_logic_vector(7 downto 0);
send: in std_logic;
ok: out std_logic;
END COMPONENT;
type d_type is array (0 to 15) of std_logic_vector(7 downto 0);
constant data1: d_type:=(x"22",x"53",x"45",x"4c",x"41",x"4D",x"20",x"46",x"50",x"47",x"41",x"22",x"00",x"00",x"00",x"00");
signal counter : std_logic_vector(3 downto 0):=(others=>'0');
signal counter_next : std_logic_vector(3 downto 0):=(others=>'0');
signal active : std_logic;
signal ok : std_logic;
signal inpt : std_logic_vector(7 downto 0);
begin
Inst_uart_tx : uart_tx PORT MAP (clk=>clk,reset=>'0',inpt=>inpt,send=>active, ok=>ok,rslt=>rslt);
process(clk)
begin
if rising_edge(clk) then
counter<=counter_next;
end if;
end process;
active<='1' when start='1' and counter <"1101" else '0';
counter_next<=counter+1 when ok='1' else counter;
inpt<=data1(conv_integer(counter));
end davranis;
tx code
library ieee;
entity uart_tx is
	port
			 clk,reset,send : in std_logic;
			 ok,rslt : out std_logic
end uart_tx;
architecture davranis of uart_tx is
 constant clk_index:integer:=5200;
 type statu_index is(wait_txd,start_txd,send_txd,stop_txd);
 signal statu,statu_next: statu_index;
 signal N,N_next:integer;
 signal counter,counter_next: integer;
 signal data,data_next: std_logic:='0';
 begin
	Bellek:process(clk,reset)
	begin
		if reset='1' then
			statu<=wait_txd;
			counter<=0;
			data<='1';
			N<=0;
		elsif clk='1' and clk'event then
			statu<=statu_next;
			data<=data_next;
			N<=N_next;
		end if;
	end process;
	kombinasyonal: process(statu,counter,N,send,inpt,data)
	begin
	statu_next<=statu;
	counter_next<=counter;
	data_next<='1';
	N_next<=N;
	ok<='0';
		case statu is
			when wait_txd=>
				if send='1' then
				   statu_next<=start_txd;
				end if;
			when start_txd=>
			counter_next<=counter+1;
			data_next<='0';
				if counter=clk_index then
				   counter_next<=0;
					statu_next<=send_txd;
				end if;
			when send_txd=>
			data_next<=inpt(N);
					if N=7 then
					   statu_next<=stop_txd;
			         N_next<=0;
					else
					N_next<=N+1;
				end if;
			counter_next<=0;
			end if;
			when stop_txd=>
				if counter= clk_index then
					counter_next<=0;
					ok<='1';
					statu_next<=wait_txd;
			end if;
		end case;
	end process;
rslt<=data;
end davranis;
How do you determine that the design is not "working"?
How is the shown code used on the board, is test the top design and how is start generated? What's the clock frequency?
Did you verify code operation in simulation with a test bench?
The "test" state machine doesn't even have a reset. How can you guarantee that it's started properly?
Before doing any work on the evaluation board you can check if your design works by doing simulation.
I threw it into Modelsim and used force statements to generate the clock, start, and forced a reset to the sub-module reset and it seemed to be running with a 8-bit, no parity, 1 stop bit mode (I didn't examine it carefull, just checked it was doing something and sending bits). So maybe the OP isn't using the correct baud rate or has the parity setting wrong.
