TheImpervious
Newbie level 1
- Joined
- Apr 11, 2010
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- United States
- Activity points
- 1,290
Hello all. I'm trying to make a triangle wave generator which will act as the pulse train for PWM. Based on the power specifications, I can only use a single opamp to generate the triangle wave (it is intuitive to use two: a square wave generator and an integrator). To do this, I am using a Schmitt trigger to generate a square wave with a 741. Due to the slow slew rate of the 741, the wave at the output closely resembles a triangle wave at 20kHz. My issue, however, is that I need the wave to oscillate from 0-5v, and I cannot figure out how to level-adjust the voltage and still get oscillation. This may a gross oversight by an inexperienced electronics student, but any advice would be greatly appreciated. Thank You!
