anboli
Full Member level 2
HI to all,
I had attached the Triac switching circuit here, I removed entire DC supply in the connector(CON2) and also a signal pins (CON9). Only AC supply is connected in the board. While Im Switching AC supply ON and OFF, during that time i getting the flickering in power ON led and output led (ie., LD9 and LD2 respectively). So i suspected with MOC3021 IC and I removed it and checked, now LD9 IS FLICKERING and LD2 IS NOT FLICKERING. I dont know how the LED is flickering during switch ON and OFF the AC supply.
Please let me know the reason for this flickering..
Thanks in advance,
anboli.c
Thanks in advance,
anboli.c
