Transistor to switch circuit to ground
Re: Transistor to switch circuit to grond
Dear neazoi
Hi
What is the line that the emitter of RD16 connected to ? is that ground ?
Best Wishes
Goldsmith
You need a series resistor connected to the base of the PNP.
A 1K should do it.
Otherwise you are shorting the emitter base junction to ground.
Use a NPN transistor/ N channel MOSFET...
Dear neazoi
Hi
Best Wishes
Goldsmith
it is connected to a resistor which is tied to vcc
---------- Post added at 15:44 ---------- Previous post was at 15:41 ----------
can I use an npn without the driver transistor and a 1k base series resistor?what other smaller transistors can I use for 200mA switching?
Use for example a BD135/BD137/BD139 as in the previous diagram.
I wold like to avoid altering the driver configuration. would a 1k series resistor be enough? I think the BD transistors are overkill. could I use a 2n4124?
