Rambo
Member level 3
transistor problems
I am building a electronics board for my paintball gun but I am having some problems using the transistor to switch. For some reason the transistor isn't switching enough current to drive the solenoid. I made a small schematic to show what the problem is. If it helps, on the top schematic when the solenoid actually does work the voltage across the battery is about 2.5 volts and on the schematic that I try and use the transistor the voltage across the battery is about 8 volts. Any input would be helpful.
