neazoi
Advanced Member level 6
Hello,
I have some identical transformers, intended for stepping down 220v to 6v.
In a reverse configuration, can I drive their 6V inputs in parallel and their 220V outputs in series so I can get 440v AC? (I am worrying about the HV insultion breakdown)
I have already read this article **broken link removed** about correct phasing, but I just need to make sure that the 440V will have no effect in the transformer windings, otherwise rated for 220v).
I also worry about the impedance mismatch from the first transformer secondary to the parrallel connected primaries of the other two transformers.
The attached schematic is what I am trying to do.
This might be usefull when a custom HV transformer is unavailable and a high voltage can be produced by more smaller widely available (and possibly cheaper) transformers.
Maybe more output transformers may be connected in series for higher voltages?
