Do you actually need to design one yourself? If you just need to use such a transformer, you could probably just use an old neon sign transformer (NST).
I suggest you to take out flyback transformer from old television....but as it is working on 15625Hz frequency you must be switch its supply using IGBT or MOSFET even though it is cost effective solution from such circuit you can generate about 15Kv easily.......
