transconductance gm can be complex??
So.nia
Member level 3
hello all ;
i need to knew , if the transconductance of circuit (op amp with transistor MOS ) can be complex??
regards
Yes, from definition the transconductance is current divided by voltage and if you include frequency-dependent components in your calculation gm becomes complex, but normally at higher frequencies.
gm can be complex but it is normally defined as a scaler in product descriptions. The frequency depend components are listed in other parameters such as frequency response or phase shift.
