Tracert reply contain both ip and hostname
aneesholv
India ,kerala
Hai
When I trace route to google, It shows following ip paths .Here I have a doubt, when we traceroute a domain name , result will shows its path ip interface. I think these all ip interface will be interface of the router of its path , then how this hostname came from ? Does router interface have hostname also ? Please explain the working of trace route and its resultant ..
C:\Documents and Settings\mmfm>tracert google.com
Tracing route to google.com [74.125.236.105]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 10.1.197.250
2 28 ms 28 ms 28 ms 10.1.199.229
3 29 ms 29 ms 29 ms 10.1.191.252
4 54 ms 62 ms 67 ms 115.114.36.25.static-ernakulam.vsnl.net.in [115.
114.36.25]
5 40 ms 41 ms 40 ms 59.165.191.49.man-static.vsnl.net.in [59.165.191
.49]
6 52 ms 77 ms 64 ms 115.114.85.38
7 59 ms 80 ms * 115.114.85.245
8 130 ms 118 ms * if-6-2.tcore2.SVW-Singapore.as6453.net [180.87.3
7.14]
9 82 ms 81 ms * if-2-2.tcore1.SVW-Singapore.as6453.net [180.87.1
2.1]
10 169 ms * 197 ms 72.14.220.134
11 148 ms 137 ms * 66.249.95.122
12 104 ms 113 ms 100 ms 66.249.94.75
13 107 ms * 133 ms 209.85.251.94
14 110 ms 130 ms 140 ms 216.239.48.177
15 129 ms * 103 ms bom03s01-in-f9.1e100.net [74.125.236.105]
Trace complete.
Windows' tracert program automatically resolves IP addresses to host names as well, if possible. So if a router has a name registered to it, then you will see that name. There is no reason why a router cannot have a hostname; it is a networked device with an IP address like any other device.
You can disable name resolution with the -d switch which can allow tracert to run more quickly.
