henrychuks
Newbie
i am new to PIC microcontroller. while trying to programme a HEX file i compiled with MikroC compiler, it works fine on simulation with Proteus but show error on programming the controller, the controller erases successfully. but during programming ,the process fails and some configuration bit error is displayed on the window
The image of the error message is attached here.
Please Help me out!!!
The error message is CONFIG 0x000000 Buf_val:0x4A IC_Val:0x7A and also if i disable this setting i.e.config.fuse bits, the burning process is successful. can we ignore this setting and burn the controller??
I use TL866 minipro Universal programmer."ERROR! CONFIG 0x00000 Buf_Val 0x4A IC_Val 0x7A"
