tl431 and optocoupler feedback for sg35252
babatundeawe
Full Member level 5
Nigeria
can someone help me fine tune this circuit for feedback/error correction for sg3525 pushpulll configuration. i need to get the values of the resistor right. i dont want to use a transformer in between just want to sense the voltage directly.
thanks
  • feedback.rar
I can help but I could not open the file you posted
I extracted your file. is it a Tinycad file?
thanks picgak,
just downloaded it now and it did open. u can use proteus to open it.
i hav converted it to pdf
thanks
  • feedback.pdf
I have opened your circuit and made a slight change in it (see fig) so what is your required voltage at the output point which I marked as V
thanks
ok i want to use this as a feedback mechanism for sg3525 pwm inverter. so i wish to measure the output voltage directly (230v)
thanks for your help
use 56k for R2 and 2.2k variable as Rv1 give 2.5v as ref to pin2 of sg3525
TL431
Vka - 37V (MAX)
In this scheme, it will burn.
+V1 <= Vka_max(37V)
@pplus
can u tell what u mean by Vka? is the cathode voltage of tl431 or that of the optocoupler?
thanks
it means maximum voltage the TL431 can withstand is 37v
so +V1 marked in above circuit should not be above 37V
ok guys i think ihave to order for another one cos i guess this one i have appears to be damaged due to high voltage.
