- Joined
- Jul 4, 2009
- Messages
- 16,276
- Helped
- 5,140
- Reputation
- 10,309
- Reaction score
- 5,132
- Trophy points
- 1,393
- Location
- Aberdyfi, West Wales, UK
- Activity points
- 137,753
For amazing light displays for almost zero cost, there is a simple alternative. Use one or more laser LEDs, the pen things that cost a dollar each. On top of your loudspeaker cabinet mount one small loudspeaker, facing upward and glue one mirror per Laser to it's cone. The mirrors should be as small as possible so they don't restrict the cone flexure too much, 1/4" square should be big enough. If you use more than one, position them at different distances from the cone center so they move slightly differently to each other. Shine the lasers at close range on the mirror and as the cone moves in time with the music it will draw patterns on the ceiling!
There are lots of variations on this theme, for example using more than one loudspeaker and reflecting the light via two mirrors or if you really want to impress your friends, get hold of a multi-faceted mirror ( a tube with say 8 flat mirrors around it's circumference ) and spin it with a motor. When you shine a laser on it you get a straight line drawn as the reflected light sweeps from side to side. Then use the loudspeaker trick to reflect the laser before it hits the spinning mirror and you get an oscilloscope trace of the waveform on your ceiling!
You can combine it with the comparator circuit to make the laser flash on and off at the same time.
I did an experiment a number of years ago using two spinning mirrors, one to deflect the light left to right and one at slower speed to deflect it top to bottom. I used a focussed LED as lasers have limited brightness adjustment and fed a video waveform to the LED through a power driver. The result was a giant TV picture on the wall! The principle isn't new and the quality was horrible so it isn't marketable but as an experiment it was quite entertaining.
Brian.
Brian.
