ken_ooi
Member level 1
I'm running physical optimization for my design using physical compiler.
Pls advice what is the best way to constraint the timing for all the scan in & scan out ports.
Here are some option i can think of but don't know which one is better, or whether there are other appropraite way to constraint scan pin timing?
1) set multicycle path on all the scan in pins
2) no timing constraint for the scan in and scan out pins
