Timing Budgeting between Blocks
GDesign
Newbie level 5
Newbie level 5
I need to do the following budgeting:
Block 1 --------> AXI Stream Interface --------->Block2
At the moment:
clock Block1 is 500MHz and input/output delays are set to 50%
If I need to increase the clock of Block1, for example to 2GHz, I think that I should change the input/output delay constraints. Am I wrong ? What is the approach that I must follow to prevent setup violation ?
Many thanks,
GDesign
Input and Output SDC constrains are used to inform the tool about external interfaces - I.E: the pins of your device. This isn't your case.
Is Block 1 synchronous to Block 2 ?
If not - you'll have to ensure proper clock domain crossing between the 2 (use a dual clock FIFO).
many thanks for your reply.
Block1 is an external block(macro) that is connected by AXI to Block2.
I am in a very early stage of my design and I would like a method to have a first budgeting.
Sorry for the confusion.
GDesign
Yes, Block1 is a macro(ADC, DAC, CPU, etc).
I think you are confused on what budgeting is and where/when it applies. Unless there is a combinational path that starts at block1 and ends at block2, there is no need for budgeting. Just input/output delay modelling.
Yes, that is what I am asking. My first enquiry was:
"I think that I should change the input/output delay constraints. Am I wrong ?"
Are you at a company? Please ask a more senior person to explain these concepts to you because you are still asking the wrong questions. The concept of input/output delay is meant to model external interfaces.
At the moment:
Many thanks,
GDesign
I think you should change the clock period in the create_clock definition of block1 clock.
