Thermocouple Transducer circuit
WinterInJuly
Member level 4
Member level 4
thermocouple circuit
Does anybody give me a circuit which is used to measure Thermocouple voltage and it's output is about 10mV/0C?
thermocouple transducer
You can build an amplifier as per this example:
https://www.5bears.com/circuits.htm
or
Goto Maxim web site :
They offer several circuits (samples and data sheets) to operate with thermocouples.
Regards,
IanP
use ad595 from analog device.
ad594 circuit schematic
Thanks for your reply!
AD595/AD594 is very good but it's so expensive
transducer as thermocouple
use sigma delta converters like as ADS1216 from TI to connect THC to micro,(sensor to digital,directly),you can also use other sigma delta ADCs.
ads1216
Take a look also at this thread: **broken link removed**.
Usualy, thermocouples (TCs) are not very cost-effective temperature sensors, when you need to measure just one temperature (obviously, TCs have lots of other advantages). They can be quite cost-effective, when you need to measure muiltiple temperatures. TCs can be switched with relays, if you need to sense low temperature. Or with solid-state analog switches (e.g. CD4051), if you're working with high temperatures.
