Theory behind the UltraWide Band character in the attached paper.
vishal_sonam
Full Member level 3
Hello I working on the attached paper and i want to know to the reason behind the enhanced bandwidth.
What happened to it using the L shaped ground plane that helped to have wide band characteristic.
with best regards.
Vishal
  • 12.pdf
If vertical part of L is removed the resulting structure is typical uvb antenna.
Vertical part works as reflector i think, makes the antenna directional.
