tangjinchuan
Newbie level 3
Dear all,
I am writing a report to explain every parameters of the specifications of a WCDMA chip RF3267.
But i have a problem about the Harmonic Output (2fo) in its data sheet. The value is -15dBm under Pout +28dBm which converted to dBc is -43dBc. This is the spec:https://www.rfmd.com/CS/Documents/3267DS.pdf
However in wcdma standard spec, 5.11 Spurious Emissions. It has a -30dBm in the 1MHz bandwidth. And it's power is class 3 with a test power value 24dBm(tolerance +1/-3), which means the minimun requirement is -30dBm-24dBm = -54 dBc.
Can i say that this chip does not meet the standard of WCDMA.
Or i may do something wrong in the calculation or consideration.
Please help me!!! Thanks!
