helen.liu
Newbie level 6
Hi all,
At present, I study the CDMA base station radio board, which is the digital IF architecture, and used for PCS band, but I am confused many things, as following:
1) For TX output, I find the SRX signal is from the radio board TX output signal, SRX is used for pre-distortion. I think this is used to compensate the nonlinear of the PA, but why the SRX signal is used the radio board TX output and not use the PA output signal?
2) This radio board contain TX, RX, RX diversity, SRX and TDU, I don’t know why need TDU part? This radio board is for PCS band, and the TDU part is only the frequency synthesizer output around 1960MHz.
3) Usually, what is the dynamic range of the radio board TX and RX?
Thank you
Thank you
