testbench simulation using modelsim.
herwis
Newbie level 5
I am trying to simulate a program using testbench on modelsim, but every time it gives me this error on modelsim:
# ** Warning: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, the result will be 'X'(es).
# Time: 0 ps Iteration: 0 Instance: /testhw7/u1/u3/rom1
# ** Warning: CONV_INTEGER: There is an 'U'|'X'|'W'|'Z'|'-' in an arithmetic operand, and it has been converted to 0.
# ** Error: Illegal lpm_address_control property value for LPM_RAM_ROM!
# ** Error: Illegal lpm_outdata property value for LPM_RAM_ROM!
# ** Error: Unknown INTENDED_DEVICE_FAMILY UNUSED
# Time: 0 ps Iteration: 1 Instance: /testhw7/u1/u3/rom1
# ** Note: simulation done
# Time: 20 us Iteration: 0 Instance: /testhw7
the testbench:
library ieee;
use ieee.std_logic_1164.all;
entity testhw7 is
end testhw7;
architecture structure of testhw7 is
constant clockperiod : time:=40ns;
constant Numofcycles : integer:= 1000;
component hw7
port(clk : in std_logic;
PixelClk : out std_logic;
VGABlankn : out std_logic;
hsync : out std_logic;
vsync : out std_logic;
R : out std_logic;
G : out std_logic;
B : out std_logic);
end component;
signal clk : std_logic;
signal PixelClk : std_logic:='0';
signal VGABlankn : std_logic;
signal hsync : std_logic;
signal vsync : std_logic;
signal R : std_logic;
signal G : std_logic;
signal B : std_logic;
begin
u1: hw7 port map (clk=>clk, PixelClk=>PixelClk, VGABlankn=>VGABlankn,
hsync=>hsync, vsync=>vsync, R=>R, G=>G, B=>B);
clockgen : process
variable cycle : integer range 0 to 1000:=0;
begin
for cycle in 1 to Numofcycles loop
clk<='1';
wait for clockperiod/2;
clk<='0';
end loop;
report " simulation done";
wait;
end process;
end structure;
any help is appreciated.
Reactions: herwis
    herwis
Thanks alot, now i got rid of the errors, but the problem it gives me "U" in the output!!!!
U indicates Uninitialized in VHDL. The outputs may not be driven properly
Glad you found it. :)
As shanmugaveld pointed out, the "U" are Uninitialized. Depending on your design, an U can be appropriate ... or not. The U during simulation merely means that at that point in time it 1) has not been assigned an initial value at the start, and 2) up until now no assignment with a known value has been made yet.
You can provide an initial value for the registers related with your U signal.
