Pourrahim
Newbie level 1
Hi
I was trying to write a Test bench for HEAP and simulate it using nclaunch (Cadence). But I cant get acceptable results. For some reason I do not have my input (din) in my wave form. Here is the wave form and the code and the test bench. can any one help me with this
Here is the Code
and here is my Test bench
Here is the Code
// Model of a heap.
// The heap holds WORDS keys, each of BITS bits ordered in ascending order.
// Keys may repeat. The key in first position is always a minimum key.
// The heap supports 4 operations:
// - NOOP: remain idle
// - PUSH: add a key to the heap if it is not full
// - POP : remove the first element from the heap if it is not empty
// - TEST: check the heap property
// When ready is asserted, dout gives the minimum value of the keys held
// in the heap. Commands are accepted only when ready is asserted.
// The number of bits in a key is the logarithm of the number
// of slots in the heap, so that all keys may be distinct.
// Author: Fabio Somenzi <Fabio@Colorado.EDU>
//typedef enum {NOOP, PUSH, POP, TEST} Op;
//typedef enum {IDLE, PUSH1, PUSH2, POP1, POP2, POP3, TEST1, TEST2} State;
module heap(clock,cmd,din,dout,ready,full,empty,error);
parameter BITS = 2;
parameter WORDS = 4;
parameter MSW = WORDS-1;
parameter MSB = BITS-1;
// FOR State
localparam IDLE = 3'b000;
localparam PUSH1 = 3'b001;
localparam PUSH2 = 3'b010;
localparam POP1 = 3'b011;
localparam POP2 = 3'b100;
localparam POP3 = 3'b101;
localparam TEST1 = 3'b110;
localparam TEST2 = 3'b111;
// FOR CASE
localparam NOOP = 2'b00;
localparam PUSH = 2'b01;
localparam POP = 2'b10;
localparam TEST = 2'b11;
input clock;
input cmd;
input [MSB:0] din;
output [MSB:0] dout;
output ready;
output full;
output empty;
output error;
// Op wire cmd;
reg [2:0] State;
reg [BITS:0] nitems, posn;
reg [MSB:0] h0, h1, h2;
reg [MSB:0] h [0:MSW];
//State reg State;
reg error;
wire [BITS:0] prnt, lft, rght;
integer j;
initial begin
State = IDLE;
nitems = 0;
posn = 0;
h0 = 0;
h1 = 0;
h2 = 0;
error = 0;
for (j = 0; j < WORDS; j = j+1)
h[j] = 0;
end
assign dout = h[0];
assign ready = State == IDLE;
assign full = nitems == WORDS;
assign empty = nitems == 0;
function [BITS:0] parent;
input [BITS:0] i;
reg [BITS:0] tmp;
begin: _parent
tmp = i-1;
parent = {1'b0,tmp[BITS:1]};
end
endfunction // parent
function [BITS:0] left;
input [BITS:0] i;
begin: _left
left = {i[BITS-1:0],1'b0} + 1;
end
endfunction // left
function [BITS:0] right;
input [BITS:0] i;
reg [BITS:0] tmp;
begin: _right
tmp = i+1;
right = {tmp[BITS-1:0],1'b0};
end
endfunction // right
always @ (posedge clock) begin
case (State)
IDLE:
case (cmd)
PUSH: if (full == 0) begin
posn = nitems;
h0 = din;
nitems = nitems + 1;
State = PUSH1;
end
POP: if (empty == 0) begin
nitems = nitems - 1;
posn = 0;
h0 = h[nitems]; // watch out for the extra bit!
h[0] = h0;
State = POP1;
end
TEST: begin
posn = 1;
error = 0;
State = TEST1;
end
NOOP: ;
endcase // case(cmd)
PUSH1: begin
h1 = h[prnt];
State = PUSH2;
end
PUSH2: if (posn == 0 || h1 <= h0) begin
h[posn] = h0;
State = IDLE;
end else begin
h[posn] = h1;
posn = prnt;
State = PUSH1;
end
POP1: begin
h1 = h[lft];
State = POP2;
end
POP2: begin
h2 = h[rght];
State = POP3;
end
POP3: begin
if (lft < nitems && h1 < h0 &&
(rght >= nitems || h1 <= h2)) begin
h[posn] = h1;
posn = lft;
State = POP1;
end else if (rght < nitems && h2 < h0) begin
h[posn] = h2;
posn = rght;
State = POP1;
end else begin
h[posn] = h0;
State = IDLE;
end
end
TEST1: if (posn >= nitems) begin
State = IDLE;
end else begin
h1 = h[prnt];
State = TEST2;
end
TEST2: if (h[posn] < h1) begin
error = 1;
State = IDLE;
end else begin
posn = posn + 1;
State = TEST1;
end
endcase // case(State)
end
assign prnt = parent(posn);
assign lft = left(posn);
assign rght = right(posn);
endmodule // heap
// Test bench
module test;
parameter BITS=2;
//inputs and outputs
reg clock;
reg [BITS-1:0]cmd;
reg [MSB:0] din;
wire [MSB:0] dout;
wire ready;
wire full;
wire empty;
wire error;
//Instantiation
heap H (.clock(clock),
.cmd(cmd),
.din(din),
.dout(dout),
.ready(ready),
.full(full),
.empty(empty),
.error(error));
initial begin
clock=1'b0;
cmd=2'b00;
din=2'b00;
end
always begin
cmd= 2'b00;
din= 2'b00;
#9;
cmd=2'b01;
din=2'b11;
#9;
cmd=2'b11;
din=2'b10;
#9;
din=2'b01;
#9;
$stop;
end
always begin :Clock_Generator
#5 clock =!clock;
end
endmodule
