telangamey_ei
Junior Member level 1
Hi Guys,
I don't know either if this is very simple question to be put but I stuck at this point.
Kindly, let me know if there is any special command to be used in XILINX ISE to run the process "Simulate Behavioral Model" through TCL Console directly.
I tried with "process run Behavioral Check Syntax -instance <name>" command and this works fine, but when I tried with "process run Simulate Behavioral Model" it doesn't works out. I tried with couple of other options as well but nothing works. My O.S. is Windows 7.
-Thanks :smile:
-Thanks :smile:
