Tcad sentaurus region calling error
EngAmira
Newbie level 6
Description:
I've a question regarding below structure file command , it is used to define the channel region in multifin finfet as n is number of fins and t is the order of the fin
I got error when trying to call the channel region in other file I need to call channel 1, channel 2 and so on depending on the fin order so what is the right syntax for calling it
//////////////////structure file////////////////////////////////
;;;;;;;silicon Channel;;;;;;;
(define t 0)
(do (( n 0 (+ n 1))) ((> n (- @Nfin@ 1)))
(sdegeo:create-cuboid (position (+ (* -1 (- (/ SubWidth 2) HalfWidth))(* pitch t)) (* -1 (+ HalfLength @Overlap1@)) 0) (position (+ (* -1 (- (/ SubWidth 2) HalfWidth)) @tSili@ (* pitch t)) (+ HalfLength @Overlap1@) @H@) "Silicon" (string-append
"Channel" (number->string t)))
/////////////////Sprocess.cmd file///////////////////////////////////
region name=Channel (t) mySiGe change.material
I got syntax error when calling using this method please advise with the correct method
