you will have extra clock cycles( equal to no of pipeline stages) are available to close the time for the scanout to pads instead of meeting the scanout to pad in single clock cycle.
But I see someone said:
When DFTmax scan compression is used,
compression block can produce excessive toggling on scan output pads.
To prevent this, clocked output shall be used (tail registers).
