Synthsis error using DC
bzaki
Junior Member level 3
Hi
i'm a design compiler beginner and i faced an error in the analyze step. This error is produced when i use a function in port mapping(instaintiating a component). For example
myunit: TESTCOMPONENT Generic Map(input_size) port map(INPUT_A(My_Function(input_size) downto 0),Output);
The error=>"Signal or port name expected as actual in association element"
this error can be overcomed by assigning the function to a temporaray signal outside the port map as:
INPUT_A_temp <=INPUT_A(My_Function(input_size) downto 0);
myunit: TESTCOMPONENT Generic Map(input_size) port map(INPUT_A_temp,Output);
Moreover, when i instantiate a component in a 'FOR .. GENERATE' statement, so i have to use a 2D array as a temporary signal.However, if the signal
inside the port map is a 2D array, then, i have to use a 3D array which is not synsiziable!!
I appreciate any help or hints.
Thanks in advance
