sree_vlsi
Newbie level 3
design compiler is not enabled
Hi Everyone...
I have installed Redhat Linux Enterprise 5 on my machine... When I tried to install Synopsys Design Compiler version vX-2005.09-SP4 using synopsys installer.. At the end I have got an error as below...
DO_INSTALL /usr/synopsys/admin/install/syn/bin/install_psyn -r /usr/synopsys -plat " linux"
ERROR : Failed to execute /usr/synopsys/admin/install/syn/bin/install_psyn
ERROR :
Installing Physical Compiler ...
Setting up environment for Astro/Milkyway ...
The PC installation is not complete without Milkyway.
Please ensure that Milkyway is already installed or install it now.
Milkyway installation is a separate step, please see the installation guide for details.
Once Milkyway is installed please run the script /usr/synopsys/admin/install/syn/bin/setup_astro_env
When I tried to run the dc_shell from the the shell prompt I got the erroe message as below...
Fatal: Design Compiler is not enabled. (DCSH-1)
I'm in urgent need of Design Compiler.... Can you give me a solution to rectify this problem????
Hi Everyone...
ERROR :
