I want to simulate a synchronous switched extraction circuit in pspice. Here the voltage across the capacitor controls opening and closing of the switch. How can I model switch in pspice.
If you don't mind can you please try this circuit once because I tried several times using voltage controlled switch. I don't know where am making the mistake since am not getting the proper waveform with charging and discharging phase.
The circuit can surely work, but I don't know any parameter you have chosen. It would be better if you show your results, e.g. simulation waveforms and tell how they differ from your expectations.
