this is a question always there.
1. if u do test chip , u can try two type of connections
2. if ur ADC is integrated in SOC, usually pad is insufficient, u should consider again.
3. if body effect affect ur ckt, especially those cascode amp, u had better connect SUB to near GND first. otherwise ur output swing maybe limited by the cascode mos.
