ORG 0x0004
;BTFSC CHG,1
;GOTO LED_IND
MOVWF R_72
MOVF STATUS,W
MOVWF R_70 ;satus_temp
MOVF PCLATH,W ;pc_temp
MOVWF R_71
CLRF PCLATH
BTFSC STATUS,RP0
GOTO Label_0002
GOTO Label_0004
Label_0002 MOVF R_72,W
BCF STATUS,RP0
MOVWF R_72
BSF STATUS,RP0
MOVF R_70,W
BCF STATUS,RP0
MOVWF R_70
BSF STATUS,RP0
MOVF R_71,W
BCF STATUS,RP0
MOVWF R_71
Label_0004 BTFSC R_22,5
GOTO Label_000B
MOVLW 0x81
BSF STATUS,RP0
MOVWF T2CON
BCF STATUS,RP0
BCF R_22,6
CLRF R_48
GOTO Label_000C
Label_000B BCF STATUS,Z
movlw 0X0B ;added for table read
subwf duty,w
BTFSS STATUS,Z
GOTO Label_000C
BCF STATUS,Z
MOVF 0x48,W
BTFSC STATUS,Z
BCF R_22,6
BTFSC STATUS,Z
GOTO Label_000C
MOVWF R_41
BSF R_22,6
BSF STATUS,RP0
INCF T2CON,f
BCF STATUS,RP0
Label_000C BCF STATUS,Z
movlw 0X01
subwf duty,w ;added for table read
BTFSS STATUS,Z
GOTO Label_000D
BTFSS R_43,0
GOTO Label_000E
BCF PORTC,2 ;CCP1 out
CLRF CCP1CON
CLRF CCPR1L
CLRF CCPR1H
MOVLW 0x0C
MOVWF CCP1CON
BCF R_43,0
BCF PORTC,1
BSF PORTC,3
MOVF R_45,W
MOVWF R_46
BTFSC R_43,1
BSF R_43,2
BTFSS R_43,1
BCF R_43,2
BTFSC R_22,1
GOTO Label_000F
DECFSZ R_4A,f
BTFSS R_43,2
BSF R_22,1
BTFSS R_43,2
GOTO Label_000F
DECF R_51,f
;MOVLW 0x79
MOVLW 0x40 ;64.8% DUTY
SUBWF R_51,W
;MOVLW 0x79
BTFSS STATUS,C
MOVWF R_51
GOTO Label_000D
Label_000E BCF PORTC,2
CLRF CCP1CON
CLRF CCPR1L
CLRF CCPR1H
MOVLW 0x0C
MOVWF CCP1CON
BSF PORTC,1
BCF PORTC,3
BSF R_43,0
MOVF 0x45,W
MOVWF R_46
BTFSC R_43,1
BSF R_43,2
BTFSS R_43,1
BCF R_43,2
BTFSS R_22,1
GOTO Label_000D
Label_000F BCF STATUS,C
RRF R_46,f
BCF STATUS,C
RRF R_46,f
BTFSS R_43,2
GOTO Label_0010
MOVF R_46,W
SUBWF R_51,f
;MOVLW 0x79
BTFSS STATUS,C
MOVWF R_51
MOVF R_51,W
SUBLW 0x3F
;SUBLW 0x78
;MOVLW 0x79
MOVLW 0x40 ;64.8% DUTY ??????????
BTFSC STATUS,C
MOVWF 0x51
GOTO Label_000D
Label_0010 MOVF R_46,W
ADDWF R_51,f
BTFSC STATUS,C
GOTO Label_0011
MOVLW 0xFF
SUBWF R_51,W
BTFSS STATUS , C
GOTO Label_000D
MOVLW 0xFE
MOVWF R_51
Label_000D CLRF R_53
movlw 0X07
movwf pclath
call table1
MOVWF R_3A
BCF STATUS,C
RRF R_3A,f
BCF STATUS,C
RRF R_3A,W
MOVWF R_3B
BCF STATUS,C
RRF R_3B,W
MOVWF R_3C
BCF STATUS,C
RRF R_3C,W
MOVWF R_3D
BCF STATUS,C
RRF R_3D,W
MOVWF R_3E
BCF STATUS,C
RRF R_3E,W
MOVWF R_3F
BCF STATUS,C
RRF R_3F,W
MOVWF R_40
COMF R_51,W
MOVWF R_58
DECF R_58,f
;movlw 0X60 ;?????????????????
MOVLW 0x80
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0012
Label_001A MOVLW 0x40
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0013
Label_001B MOVLW 0x20
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0014
Label_001C MOVLW 0x10
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0015
Label_001D MOVLW 0x08
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0016
Label_001E MOVLW 0x04
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0017
Label_001F MOVLW 0x02
SUBWF R_58,W
BTFSC STATUS,C
GOTO Label_0018
GOTO Label_0019
Label_0012 MOVF R_3A,W
ADDWF R_53,f
BTFSC STATUS,C
GOTO Label_0011
MOVLW 0x80
SUBWF R_58 , f
GOTO Label_001A
Label_0013 MOVF R_3B,W
ADDWF R_53,f
BTFSC STATUS,C
GOTO Label_0011
MOVLW 0x40
SUBWF R_58,f
GOTO Label_001B
Label_0014 MOVF R_3C,W
ADDWF R_53,f
BTFSC STATUS , C
GOTO Label_0011
MOVLW 0x20
SUBWF R_58,f
GOTO Label_001C
Label_0015 MOVF R_3D,W
ADDWF R_53,f
BTFSC STATUS,C
GOTO Label_0011
MOVLW 0x10
SUBWF R_58,f
GOTO Label_001D
Label_0016 MOVF R_3E,W
ADDWF R_53,f
BTFSC STATUS,C
GOTO Label_0011
MOVLW 0x08
SUBWF R_58,f
GOTO Label_001E
Label_0017 MOVF R_3F,W
ADDWF R_53,f
BTFSC STATUS,C
GOTO Label_0011
MOVLW 0x04
SUBWF R_58,f
GOTO Label_001F
Label_0018 MOVF R_40,W
ADDWF R_53,f
BTFSC STATUS,C
GOTO Label_0011
Label_0019 BTFSC R_43,0
GOTO Label_0020
CLRF CCPR1L
MOVF R_53,W
MOVWF CCPR1L
GOTO Label_0021
Label_0020 BCF PORTC,2
CLRF CCPR1L
MOVF R_53,W
MOVWF CCPR1L
Label_0021 movf duty,w
BCF STATUS,Z
sublw 0X4D
BTFSS STATUS,Z
GOTO Label_0022
movlw 0X00
movwf duty ;added for table read
Label_0022 incf duty,f ;added for table read
BCF STATUS,Z
movf duty,w
sublw 0X29
BTFSS STATUS,Z
GOTO Label_0023
BTFSS R_43,0
GOTO Label_0023
PWM_REG MOVLW b'10001001' ;RA1 for OUTPUT REGULATION
MOVWF ADCON0
MOVLW 0x1A
MOVWF R_42
LOOP_11 DECFSZ R_42,f
GOTO LOOP_11
BSF ADCON0,GO
Label_0025 BSF R_22,7
BTFSC ADCON0,GO
GOTO Label_0025
MOVF ADRES,W
SUBWF R_23,W
BTFSC STATUS,C
BSF R_43,01
BTFSS STATUS,C
BCF R_43,01
MOVWF R_45
BTFSS R_43,01
GOTO Label_0026
BTFSS R_22,01
GOTO Label_0027
SUBWF R_47,W
BTFSS STATUS,C
DECFSZ R_2F,f
GOTO Label_0027
;GOTO Label_0028 ;FOR SHT-CKT TRIP(close for no trip)
Label_0026 MOVLW 0x02
MOVWF R_2F
COMF R_45,f
INCF R_45,f
GOTO Label_0027 ;end_int_2
Label_0023 BCF PIR1,1 ;no TMR2 to PR2 match
BTFSS R_22,6
GOTO Label_0006
DECFSZ R_41,f
GOTO Label_0006
BSF STATUS,RP0 ;SELECT BANK1
DECF T2CON,f ; not known
BCF STATUS,RP0 ;SELECT BANK0
BCF R_22,6
Label_0027 BCF PIR1,1 ;;no TMR2 to PR2 match
Label_0006 BCF STATUS,RP0
BCF STATUS,RP1
MOVF R_70,W
MOVWF STATUS
MOVF R_71,W
MOVWF PCLATH
MOVF R_72,W
RETFIE
How to use code tags when including code to your post?
test code tags .........
Can you please share your knowladge and your experience ?
INC_TRICKLE_DUTY: ;
'SELFCHECK PW,d'100' ;d'100'
if PWM_DUTY_CYLE > “?value?” then GOTO MAIN_FAILURE_CHECK
PWM_DUTY_CYLE = PWM_DUTY_CYLE +1
hpwm 1,PWM_DUTY_CYLE,PWM_FREQUENCY ' pwm on
goto main_failure_check
ASM Code:
INC_TRICKLE_DUTY:
incf pw,1
movf pw,w
movwf ccpr1l
;call delay40
When given 1: macro
selfcheck macro a, bxx
movlw bxx
xorwf a,0
btfsc status,z
endm
When given 2: Crystal = 16MHz
When given 3:
‘PWM Duty = (CCPR1L:CCP1CON(5:4)) x Tosc x TMR2 prescale.
MOVLW d'01'
MOVWF PW
MOVWF CCPR1L
BCF CCP1CON,4
BCF CCP1CON,5
BCF CCP1CON,0
BCF CCP1CON,1
BSF CCP1CON,2
BSF CCP1CON,3
MOVLW b'00000101'
MOVWF T2CON ‘TMR2 prescale =1:4
When given 3:
BSF STATUS,RP0
MOVLW d'166' ;6kHz CHARGING PWM
MOVWF PR2
BCF STATUS,RP0
