Terminator3
Advanced Member level 3
Here is well known design by S53MV:
http://lea.hamradio.si/~s53mv/zifssb/xband.html
where positive bias applied to diodes:
I recently found a design where biasing looks a little strange to me:
As i understand, R2 and R3 is a voltage divider. But it is placed before capacitor C1, so it does not affect diode biasing. Diodes are biased using +5V through R1 directly, without voltage divider.
R2, R3 and C1 does not look like low pass filtering. Can anyone explain purpose of R2 and R3?
Since only positive bias is available through the 10kohm trimmers for mixer balancing, the BAT14-099R packages should be oriented correctly in the circuit. In particular, one of the two packages has to be installed upside down.
