plusmartin
Newbie level 5
Greetings
I am in need of a great boost converter that enables me to generate at least 2 or 3 Amps at aprox 28V from a 12V source.
this was recommended to me: You can use MC34167. It can step down and also it can step up. Look at the circuit named "step-up/down converter" in the datasheet.
https://pdf1.alldatasheet.com/datashe...I/MC34167.html
I intend to use this for a very one of a kind battery balancer.
-Battery A (0V to 12V)
-Battery B (12V to 24V) (yes, they are connected in series)
-both are lead acid for solar applications
-i am using 24V loads but also 12V loads from battery B (12 to 24)
-unbalancing batteries is bad, therefore i need to return the energy to B, from A.
-i use the DC DC boost to take amps from battery A and deliver them to B.
-when the voltages are equal on both batteries i turn the DCDC system off until next time.
-if i use this exatly the opposite way (to charge A from B) i could have a 2way battery charge balancer
is this IC a good idea? any other models out there?
i have space restriction on my pcb.
thanks
thanks
