[SOLVED] static rom unsigned char string not pass correctly to the unsigned char array
dhakeparag81
Full Member level 2
INDIA
Hello there,
When i am try to use array of char after compilation it gives me error,"stack frame too large.
i am declare it in function,
so i used static rom unsigned char compiled successfully:smile:
But when i debug it i come to know the value of static rom..... not passed correctly to unsigned char array.:bang:
Any help?
compilation is successful.
pseudo code
void gsm_msg(unsigned char var)
     rom static unsigned char gsm_msg4[20]={"Date Halt"};
	switch(var)
		case 1:
			for(i=0;i<20;i++)
				serial_out[i]=gsm_msg1[i];
		break;
		case 2:
			for(i=0;i<20;i++)
				serial_out[i]=gsm_msg2[i];
		break;
Hello there,
Any help?
pseudo code
	switch(var)
		case 1:
			for(i=0;i<20;i++)
		break;
		case 2:
			for(i=0;i<20;i++)
		break;
Found Solution.
Actually my code is very large in size may be memory exceeded.
i used static rom far unsigned cha
check above link for clarification.
https://www.microchip.com/forums/m121587.aspx
