[SOLVED] stability of pmos current mirror
chandlerbing65nm
Member level 5
hi edaboards!
I have a simple question. In a current mirror in the attached photo. The drain current from transistor M1 is mirrored to transistor M3, but the drain current from M3 is not stable due to channel length modulation. My question is how can I make the drain current of the current mirror in transistor M3 stable or independent of the channel length modulation? Thank you for answering my question .
Use cascode devices on both sides. Anyway, if connect M1 and M2 diodes in series the current variation will be high.
Cascode, Wilson, source degeneration are all things
to try, local care-abouts will indicate which one when
you simulate and compare layout areas. Putting it all
under a local LDO is another more complex solution.
