hover
Junior Member level 2
Now I am tying to do pre-layout constrain for my project. The feature of this project is that only one 48MHz clock is available. After internal division it produces a 12MHz clock, all the output ports are synchronized to the 12MHz clock. Now I do a top level STA by putting all the inputs and outputs constraints under 48Mhz clock. The problem is that there is a max-delay violation from one input to one output and the value of violation is very high to a level of exaggeration. Should I change the constraints by constraining all outputs to 12Mhz clock?
